Single Crown Forks 160mm Lyrik RCT3 Charger Damper Debonair Spring
Fotos: Single Crown Forks 160mm Lyrik RCT3 Charger Damper Debonair Spring
Artikelbeschreibung: Single Crown Forks 160mm Lyrik RCT3 Charger Damper Debonair Spring
Selling my 27.5" 160mm Lyrik RCT3 with a charger damper and debonair spring.
I loved the fork, but I've since moved to a 29'er so I have to say goodbye to this bad boy. Stanchions are in immaculate shape. Tapered steer tube is cut to just a hair longer than 7 1/4". It's been somewhere between 50 and 100 hours since the last rebuild, so you might want to look into that. Prefer local pickup, but if you're interested, feel free to reach out.
Thanks!
Thanks!
automatisch übersetzt
Single Crown Forks 160mm Lyrik RCT3 Charger Damper Debonair Spring kaufen
85 €
Details & Spezifikationen : Single Crown Forks 160mm Lyrik RCT3 Charger Damper Debonair Spring
Anzahl | 1 |
Hersteller | Single Crown Forks |
Zustand | gebraucht, wie neu |
Versandkosten | 5 € |
Abholung | Ja |
Ort | Munich |
Angesehen | 290 × |
Momentane Betrachter | 2 |
Veröffentlicht | 28. Apr 2024 01:23 |
Endet | 28. Apr 2025 01:23 |
