Specialized Stumpjumper evo 2019
Fotos: Specialized Stumpjumper evo 2019
1.400 €
VHB
Artikelbeschreibung: Specialized Stumpjumper evo 2019
Verkaufe mein Specialized Stumpjumper evo 2019 in der Größe S2 (M) es befindet sich in einem guten Zustand und hat wenig Bikepark gesehen. Für mehr Fotos einfach Kontaktieren.
Technische Daten:
Bottom Bracket
SRAM DUB, BSA 73mm, Threaded
Shift Levers
SRAM NX Eagle, trigger, 12-speed
Crankset
SRAM NX Eagle, DUB, 165mm, 32T
Chain
SRAM NX Eagle, 12-speed
Rear Derailleur
Cassette
SRAM NX Eagle, 12-speed, 11-50t
Chainrings
Steel, 30T
WHEELS
Front Hub
Specialized, sealed cartridge bearings, 15x110mm spacing, 28h
Rear Hub
Specialized, sealed cartridge bearings, 12x148mm thru-axle, 32h
Rims
Roval Traverse 27.5, hookless alloy, 30mm inner width, tubeless ready
Inner Tubes
Presta, 40mm valve
Spokes
DT Swiss Industry
Rear Tire
Butcher, GRID casing, GRIPTON® compound, 2Bliss Ready, 27.5 x 2.6"
Front Tire
COCKPIT
Handlebars
Specialized, 7050 alloy, 6-degree upsweep, 8-degree backsweep, 27mm rise, 800mm width
Stem
Specialized Trail, 3D-forged alloy, 4-bolt, 6-degree rise
Grips
Deity, Knuckleduster, Black
Saddle
Body Geometry Henge Comp, hollow Cr-Mo rails, 143mm
SeatPost
X-Fusion Manic, infinite adjustable, two-bolt head, bottom mount cable routing, remote SRL LE lever, 34.9mm, 150mm of travel
FRAMESET
Seat Binder
Specialized bolt-type, alloy, 38.6mm
Frame
M5 alloy frame, asymmetrical design, 27.5 style-specific EVO Trail Geometry, threaded BB, fully enclosed internal cable routing, 12x148mm dropouts, sealed cartridge bearing pivots, replaceable derailleur hanger, 150mm of travel
BRAKES
Front Brake
SRAM Code R, 4-piston caliper, hydraulic disc, 220mm
Rear Brake
SRAM Code R, 4-piston caliper, hydraulic disc, 200mm
Suspension
Rear Shock
FOX FLOAT DPX2 Performance, Rx Trail Tune, EVOL Air sleeve, 3-position adjustment, 210x52.5mm
Technische Daten:
Bottom Bracket
Shift Levers
Crankset
Chain
Rear Derailleur
Cassette
Chainrings
Steel, 30T
WHEELS
Front Hub
Rear Hub
Rims
Inner Tubes
Presta, 40mm valve
Spokes
DT Swiss Industry
Rear Tire
Front Tire
COCKPIT
Handlebars
Stem
Grips
Saddle
SeatPost
FRAMESET
Seat Binder
Frame
BRAKES
Front Brake
Rear Brake
Suspension
Rear Shock
automatisch übersetzt
Specialized Stumpjumper evo 2019 kaufen
1.400 €
VHB
Details & Spezifikationen : Specialized Stumpjumper evo 2019
Anzahl | 1 |
Hersteller | Specialized |
Modell | Specialized Stumpjumper |
Zustand | neu |
Abholung | Ja |
Ort | Olpe |
Rahmengröße | M |
Federweg vorn | 150 mm |
Federweg hinten | 150 mm |
Dämpfer-Einbaumaße | 190 x 40 mm Metric |
Laufradgröße | 27,5" / 650b |
Material | Aluminium |
Gänge | 12 |
Angesehen | 1.380 × |
Momentane Betrachter | 1 |
Veröffentlicht | 19. Feb 2024 20:23 |
Endet | 19. Feb 2025 20:23 |
