Norco Shore A2 Freeride 27,5 Purple/Pink 2023 ZEB 180mm Größe L
Fotos: Norco Shore A2 Freeride 27,5 Purple/Pink 2023 ZEB 180mm Größe L
3.799,99 €
Artikelbeschreibung: Norco Shore A2 Freeride 27,5 Purple/Pink 2023 ZEB 180mm Größe L
Frameset
FRAME Aluminum Freeride, 180mm Travel, UDH, Hangerless Interface Compatible, Ride Aligned™
FORK RockShox Zeb R, Charger, 180mm Travel, 44mm Offset
REAR SHOCK RockShox Super Deluxe Coil Ultimate DH, Custom Tune 225x70mm, 400lb/in (S), 450lb/in (M), 500lb/in (L), 550 lb/in (XL)
Drivetrain
REAR SHIFTER Shimano Deore SL-M6100-R
REAR DERAILLEUR Shimano Deore RD-M6100
CRANKSET e*thirteen Helix, 30mm, 34T, 170mm
BOTTOM BRACKET e*thirteen 30mm, BSA Threaded
CASSETTE Shimano Deore CS-M6100-12, 10-51T, 12 Speed
CHAIN Shimano Deore CN-M6100
CHAIN GUIDE Norco Idler Chain Guide and Lower Guard
Brakes
FRONT BRAKE Shimano BR-MT520, 4 piston, Metallic Pads
FRONT BRAKE ROTOR Shimano RT-64, 203mm
REAR BRAKE Shimano BR-MT520, 4 piston, Metallic Pads
REAR BRAKE ROTOR Shimano RT-64, 203mm
Components
HANDLEBAR Norco 6061, 800mm, 25mm Rise
STEM e*thirteen Base, 40mm Length, 35mm Clamp
SEATPOST TranzX YSP-105 Adjustable Dropper, 34.9mm, 150mm (S), 170mm (M), 200mm (L, XL)
DROPPER LEVER Norco 1x Lever
HEADSET FSA #57E Sealed Bearing
SADDLE WTB Volt 250 Sport
GRIPS SDG Thrice Lock-On, Thin (S, M), Thick (L, XL)
Wheels
FRONT HUB Shimano Deore HB-M6010, 15x110mm Boost, Center Lock
REAR HUB Shimano Deore FH-MT510-B, 12x148mm Boost, Micro Spline, Center Lock
RIMS e*thirteen LG1 DH 27.5"
FRONT TIRE Maxxis Assegai 2.5", 3C Maxx Grip/DD/TR
REAR TIRE Maxxis Assegai 2.5", 3C Maxx Grip/DD/TR
SPOKES/NIPPLES Stainless Black
VALVES e*thirteen Tubeless
SEALANT Stan's - 200ml
Drivetrain
Brakes
Components
Wheels
automatisch übersetzt
Norco Shore A2 Freeride 27,5 Purple/Pink 2023 ZEB 180mm Größe L kaufen
3.799,99 €
Details & Spezifikationen : Norco Shore A2 Freeride 27,5 Purple/Pink 2023 ZEB 180mm Größe L
Anzahl | 1 |
Hersteller | Norco |
Modell | Norco Shore |
Zustand | neu |
Versandkosten | 80 € |
Abholung | Nein |
Ort | Pfunds |
Farbe | Pink / Blue |
Rahmengröße | L |
Federweg vorn | 180 mm |
Federweg hinten | 180 mm |
Dämpfer-Einbaumaße | Sonstige |
Laufradgröße | 27,5" / 650b |
Material | Aluminium |
Gänge | 12 |
Angesehen | 286 × |
Momentane Betrachter | 1 |
Veröffentlicht | 27. Mär 2024 09:33 |
Endet | 27. Mär 2025 09:33 |
