Rocky Mountain Vertex 990 RSL size "M" + Kind Shock LEV Ci
Fotos: Rocky Mountain Vertex 990 RSL size "M" + Kind Shock LEV Ci
635 €
VHB
Artikelbeschreibung: Rocky Mountain Vertex 990 RSL size "M" + Kind Shock LEV Ci
[left]Frame Rocky Mounatin RSL 2015 in size "M" purchased as NEW in April 2021 and sinced then used in summer seasons until October 2023. Frame is in very good technical condition - no cracks or damages of carbon, frame was coverved with protective film nevertheless it still wears signs of use, mainly seen in rear triangle - after tire and brake cable. I tried to capture all of them. Please check all the pictures. [/left]
[left]
Kind Shock LEV Ci cabon seatpost with 27.2mm diameter and 100mm of travel and remote are included. It was purchased in May 2022. Since then it was serviced 3 times, works without any issue. Lateral play between head and stanchion tube is noticeable what's normal for this seatpost.[/left]
Real weight of bare frame is: 1087 grams.
Headset is included.
Seatpost diameter: 27.2
Rear axle standard: 142mm x 12mm
Bottom bracket standard: BB92
Headset: Tapered
[left]
Headset: Tapered
automatisch übersetzt
Rocky Mountain Vertex 990 RSL size "M" + Kind Shock LEV Ci kaufen
635 €
VHB
Details & Spezifikationen : Rocky Mountain Vertex 990 RSL size "M" + Kind Shock LEV Ci
Anzahl | 1 |
Hersteller | Rocky Mountain |
Modell | Rocky Mountain Vertex |
Zustand | neu |
Versandkosten | 25 € |
Land | Polen |
Abholung | Nein |
Gewicht | 1088 grams |
Rahmengröße | M |
Steuerrohr | Tapered 1⅛″/1,5″ |
Laufradgröße | 29" |
Material | Carbon |
Angesehen | 1.179 × |
Momentane Betrachter | 1 |
Veröffentlicht | 26. Nov 2023 14:13 |
Endet | 26. Nov 2024 14:13 |
