Specialized Epic FSR Comp 2009
Fotos: Specialized Epic FSR Comp 2009
800 €
VHB
Artikelbeschreibung: Specialized Epic FSR Comp 2009
Ich Verkaufe für ein Freund sein Specialized Epic FSR Comp aus dem Jahr 2009.
Das Fahrrad wurde wenig gefahren und ist daher in einem sehr guten zustand. Der Brain Dämpfer wurde von Specialized gewartet. Die Ausstattungs Details findet ihr weiter unten.
Technische Spezifikationen
RAHMEN
Epic FSR M5 alloy, fully manipulated frame w/ ORE DT/TT, sealed cartridge bearings, 100mm travel, replaceable derailleur hanger
SUSPENSION
REAR SHOCK
Specialized AFR remote mini , BRAIN inertia valve w/ BRAIN fade and rebound adj.
FORK
Fox F100 RL, 100mm travel, air spring, compression and rebound adj. w/ LO, alloy steerer
FRAMESET
HEADSET
1-1/8"" Threadless, 10mm insertion alloy cups, sealed cartridge bearing
SEAT BINDER
7050 hard annodized alloy collar w/ QR, 34.9mm clamp ID, black
WHEELS
RIMS
Custom DT Swiss X420SL, 24mm w/ eyelets, 28/32h
FRONT HUB
Specialized Hi Lo disc, CNC flange, sealed cartridge bearing, 9mm DT RWS, alloy QR, 28h
REAR HUB
Custom Shimano M525 SL, alloy QR, 32h
SPOKES
DT Swiss 1.8mm stainless, black, alloy nipples
FRONT TIRE
Continental Race King 26x2.0""
REAR TIRE
DRIVETRAIN
FRONT DERAILLEUR
Shimano M660 SLX, DMD, top swing, dual pull
REAR DERAILLEUR
SRAM X-9, 9-speed, mid cage
SHIFT LEVERS
SRAM X-7, aluminum 9-speed trigger
CASSETTE
Shimano HG61, 9-speed, 11-34t
CRANKSET
Custom Shimano FC-M542, S: 170mm, others: 175mm
CHAIN
SRAM PC-971, 9-speed w/Power Link
CHAINRINGS
22S x 32A x 44A, 4-bolt, 104/64mm
BOTTOM BRACKET
Shimano FC-M542
COCKPIT
STEM
Specialized adjustable rise, 31.8mm clamp, 3D forged w/ CNC finish
HANDLEBARS
Specialized XC low rise 31.8mm bar, 6066 butted alloy, 6 degree up, 8 degree backsweep, 640mm wide
SADDLE
Specialized Phenom, hollow Cr-Mo rails, thin foam, S/M: 130mm, L/XL: 143mm
GRIPS
Specialized thin lock on grip (S/M) Specialized Thick lock on grip (L/XL)
SEATPOST
2014 butted alloy, single-bolt setback, S/M: 350, L/XL: 400mm
BRAKES
FRONT BRAKE
Custom Avid Elixir R SL, alloy backed organic pads, S/M: 160mm, L/XL: 185mm rotor
REAR BRAKE
Custom Avid Elixir R SL, alloy backed organic pads, S/M: 140mm, L/XL: 160mm rotor
BRAKE LEVERS
Custom Avid Elixir R Carbon SL Hydraulic, tool-less adj. reach
RAHMEN
SUSPENSION
REAR SHOCK
FORK
FRAMESET
HEADSET
SEAT BINDER
WHEELS
RIMS
FRONT HUB
REAR HUB
SPOKES
FRONT TIRE
REAR TIRE
DRIVETRAIN
FRONT DERAILLEUR
REAR DERAILLEUR
SHIFT LEVERS
CASSETTE
CRANKSET
CHAIN
CHAINRINGS
BOTTOM BRACKET
Shimano FC-M542
COCKPIT
STEM
HANDLEBARS
SADDLE
GRIPS
SEATPOST
BRAKES
FRONT BRAKE
REAR BRAKE
BRAKE LEVERS
automatisch übersetzt
Specialized Epic FSR Comp 2009 kaufen
800 €
VHB
Details & Spezifikationen : Specialized Epic FSR Comp 2009
Anzahl | 1 |
Hersteller | Specialized |
Modell | Specialized Epic |
Zustand | gebraucht, wie neu |
Land | Deutschland |
Abholung | Ja |
Ort | Wiesband |
Farbe | Gloss Red |
Rahmengröße | M |
Federweg vorn | 100 mm |
Federweg hinten | Specialized AFR Brain |
Steuerrohr | 1⅛″ |
Dämpfer-Einbaumaße | Sonstige |
Laufradgröße | 26" |
Material | Aluminium |
Gänge | 3 x 9 |
Angesehen | 2.277 × |
Momentane Betrachter | 1 |
Veröffentlicht | 1. Jun 2023 11:03 |
Endet | 1. Jun 2024 11:03 |
