Norco Optic C1 2021 Gr. S
Fotos: Norco Optic C1 2021 Gr. S
5.999 €
Preis inkl. MwSt. und zzgl. Versandkosten
Die Versandkosten können erst berechnet werden, wenn du eingeloggt bist. Anmelden
Artikelbeschreibung: Norco Optic C1 2021 Gr. S
There isn’t a single aspect of the 2020 Optic that hasn’t been examined, re-addressed and overly-scrutinized to make it a rippin’ fun short travel trail bike with the agility and confidence you need to look further up the trail.
The Optic’s carbon frame uses Norco’s Ride Aligned™ design system to create its high-speed, short-travel performance, with geometry created for confident, playful descents, railing corners and boosting jumps. The precision suspension kinematics and custom RockShox DH shock create 125mm of plush rear travel, which we’ve matched to a bump-eating 140mm Pike on every model for the control you need to keep your mind on the trail, and off of what your bike is up to.
Sure, the steep seat angle and long top tube will help you get all the power and grip you need to claw your way back up, but make no mistake, what the Optic really wants to do is rip back down again.
Every Optic is equipped with DH-focused components – because we know what kind of speed the bike inspires. Big four-piston disc brakes, wide handlebars, short stems, stiff, and burly 29er wheels with tough 2.35 tires give you the control and clarity you need to attack your favourite trails at speeds that go by in a blur on regular short-travel bikes.
Frame: Carbon Front Triangle/Aluminum Rear, 125mm Travel, Ride Alignedâ
Fork: Fox Performance Elite 36 Grip2 FLOAT, 140mm Travel, 42mm Offset
Rear Shock: Fox Performance Elite FLOAT DPX2, 190x45mm
Headset: FSA Internal Sealed Bearing
Headset Spacer: 1x10mm/2 x 5mm- Black
Grips: DMR Deathgrip
Handle Bar: One Up Carbon, 800mm, 20mm Rise
Stem: 6061 Alloy, 45mm Length, 35mm Clamp
Seat Post: X-Fusion Manic dropper, Â 31.6mm, 125mm (s), 150mm (M,L), 170mm (XL)
Seat Post Clamp: Norco Alloy Nutted Clamp
Dropper Lever: 42
Saddle: Fizik Alpaca Terra, Wingflex
Front Brake: Shimano XTR M9120, 4 Piston, Organic Pads
Front Brake Rotor: Shimano XTR MT900 Freeza, 203mm
Rear Brake: Shimano XTR M9120, 4 Piston, Organic Pads
Rear Brake Rotor: Shimano XTR MT900 Freeza, 180mm
Brake Levers: Shimano XTR
Shifter Rear: Shimano XTR M9100 I-Spec
Rear Derailleur: Shimano XTR M9100
Cassette: Shimano XTR M9100, 10-51T, 12 Speed
Chain: Shimano XTR M9100
Crankset: e*thirteen TRS Race Carbon, 32T, 170mm
Bottom Bracket: e*thirteen BB92
Front Hub: Shimano XT HB-8110-B, 15x110mm Boost, Center Lock
Front Hub Skewer: Fox Bolt Thru Axle
Rear Hub: Shimano XT FH-8110-B, 12x148mm Boost, Center Lock
Rear Hub Skewer: 148mm x 12mm TA
Spokes/Nipples: Sapim Sprint DB Stainless
Rims: Stans Flow S1 29", 32H
Front Tire: Vittoria Mazza 2.4" Trail G2.0
Rear Tire: Vittoria Martello 2.35" Trail G2.0
Sealant: Stan's Tire Sealant - 200ml
Valves: Stan's Universal 35mm Presta Valve Stem
Rim Tape: Stan's Rim Tape 55m x 30mm (Fits Flow rims)
Alle Bikes und Teile können natürlich auch gern vor Ort nach Terminabsprache besichtigt und abgeholt werden!
Sofern nicht anders angegeben, sind die angebotenen Artikel NEU.
Rechnung mit ausgewiesener MwSt. sowie volle Garantie und Gewährleistung gehören natürlich dazu.
Wir realisieren gern individuelle Aufbauten - nicht alle verfügbaren Angebote sind online, Anfragen sind immer willkommen!
Bei Fragen einfach melden!
Viele weitere Angebote findest du im MOUNTAINLOVE Bikemarkt Shop
Versandkosten Standardpakete:
DE ab 4,90€
EU ab 12,90 €
Versandkosten Kompletträder:
DE ab 49,90€
EU ab 69,90€
Zahlung im IBC:
Vorkasse
Paypal
Dropper Lever: 42
DE ab 4,90€
EU ab 12,90 €
DE ab 49,90€
EU ab 69,90€
Zahlung im IBC:
Vorkasse
Paypal
automatisch übersetzt
Norco Optic C1 2021 Gr. S kaufen
5.999 €
Verkäufer mountainlove
5/5
basierend auf 1625 Bewertungen.
mountainlove.de
Gewerbliche/r Anbieter*in
Details & Spezifikationen : Norco Optic C1 2021 Gr. S
Anzahl | 1 |
Hersteller | Norco |
Modell | Norco Optic |
Zustand | neu |
Land | Deutschland |
Abholung | Ja |
Ort | 64572 |
Rahmengröße | S |
Federweg vorn | 140 mm |
Federweg hinten | 125 mm |
Dämpfer-Einbaumaße | 190 x 45 mm Metric |
Laufradgröße | 29" |
Akzeptierte Bezahlmethoden | Überweisung |
Angesehen | 2.261 × |
Momentane Betrachter | 1 |
Veröffentlicht | 24. Sep 2021 11:50 |
Endet | 27. Sep 2024 09:39 |
